jelockwood1
Dec 13, 2011Guide
4TB hard disks
It is early days yet but 4TB disks are starting to trickle on to the market. I am aware so far of two different makes being launched they being Seagate and Hitachi. Hitachi at least have now made a ki...
mdgm-ntgr
Dec 14, 2011NETGEAR Employee Retired
Good plan. Even though it appears 4TB drives probably already work fine in general, it's possible that particular drives may have compatibility issues that need to be addressed by a firmware update. So before you add 4TB drives (once they are approved) be sure to update to the latest production firmware available at that time.
There are a couple of expansion issues to be aware of though:
1. You cannot expand past 16TB. You must factory default with that capacity in place. So if you want a single-redundant volume with 6x4TB disks you'll need to backup your data and do a factory reset. A dual-redundant volume would come in under the 16TB limit
2. Limit of 8TB for online expansion of 64-bit system (e.g. Pro) using EXT4 filesystem e.g. if original volume capacity after last factory default was 4TB you can't expand beyond 12TB online.
