jelockwood1
Dec 13, 2011Guide
4TB hard disks
It is early days yet but 4TB disks are starting to trickle on to the market. I am aware so far of two different makes being launched they being Seagate and Hitachi. Hitachi at least have now made a ki...
mdgm-ntgr
May 07, 2013NETGEAR Employee Retired
Whilst there are no 4TB disks on the compatibility list for the NVX, 4TB disks *might* work for you. What disks were in the NAS when you last did a factory default (wipes all data, settings, everything). If all four 2TB disks were installed when you last did a factory default you should be O.K. If there were any less you would need to backup your data and do a factory default.
Before replacing disks to expand your volume please downgrade to 4.2.19 or update to 4.2.23 (due for release soon, currently in public beta). There is a bug in 4.2.20-4.2.22 on 32-bit systems (e.g. NVX).
Edit: beaten.
Edit: beaten.
