bsteingraber
Apr 13, 2015Aspirant
4TB HDD on ReadyNAS 2100
Does anyone know if 4TB drives work in a 2100 V2 running 4.2.27?
I'm looking at getting 4x Seagate Desktop HDD 1.5 drives since they are appear to be a great choice based on testing...
https://www.backblaze.com/blog/best-hard-drive/
- NhellieVirtuosoYou're most welcome! Support maybe declined though since it is not on the compatibility list. But the NAS should be able to handle it though.
- bsteingraberAspirant
Nhellie wrote: You may want to check this:
https://www.readynas.com/forum/viewtopic.php?f=24&t=76764
providing that the FW that you are using is the latest, 4TB should work.
THANK YOU!!! I did not find that thread when looking.
So that answers the question if 4TB is supported by Radiator.... - NhellieVirtuosoYou may want to check this:
https://www.readynas.com/forum/viewtopi ... 24&t=76764
providing that the FW that you are using is the latest, 4TB should work. - RXLuminaryI think only up to 3TB of capacity is supported as per the compatibility list of drives for the ReadyNAS 2100. You may check it for yourself: http://kb.netgear.com/app/answers/detail/a_id/20641
