mitsitsad
Jun 03, 2014Aspirant
5TB Support? Advice needed!
Hello all, I purchase 2x5TB seagate externals a few weeks ago and finally got around to setting them up. Tore the external casing apart to find a 5tb seagate model ST5000DM000 hard drive. I found a...
mdgm-ntgr
Jun 03, 2014NETGEAR Employee Retired
The Duo v1 has no GPT support so you are limited to 2TB or smaller capacity drives. You would need a newer NAS to use higher capacity disks.
