mitsitsad
Jun 03, 2014Aspirant
5TB Support? Advice needed!
Hello all, I purchase 2x5TB seagate externals a few weeks ago and finally got around to setting them up. Tore the external casing apart to find a 5tb seagate model ST5000DM000 hard drive. I found a...
mdgm-ntgr
Jun 03, 2014NETGEAR Employee Retired
Units that work with 3TB drives will probably also work with 5TB disks.
My personal preference would be for models with Intel CPUs (e.g. 312), though you could try the 102 (ARM) if you really want to.
