TheSerpent23
Jan 20, 2017Aspirant
6.6.1 ReadyNas 104 - Not Enough space to rename or move files
After i updated to 6.6.1 i have experienced problems when i try to rename or move a file/folder. It says there is not enough space to rename the file/folder, there are over 130GB free and it says so...
- Jan 20, 2017
That's really quite full for btrfs. Can you offload some data (perhaps bringing free space up to 10%) and see if the problem still happens?
0d0a
Jan 20, 2017Tutor
TheSerpent23 wrote:After i updated to 6.6.1 i have experienced problems when i try to rename or move a file/folder.
It says there is not enough space to rename the file/folder, there are over 130GB free and it says so in the popup notification.
I can copy and delete files without any problems, i can copy the file to my local PC and rename and then move or copy it back to NAS.
It does not appear to be all files which trigger this responce, only some of the files added to the NAS after the update, if i remove all the files added after the update data it seems to run fine.
I have scrubed and balance the volumes. I have reset the permissions. I have scanned the drives and local machine with antivirus and antimalware programs.
Anyone with the same problem??
Looks Like the message I received about space left on volume ....
Try to disable virus scanning (at least until a next update!)
- TheSerpent23Jan 20, 2017Aspirant
The Antivirus is disabled and was before the update.
I have tried to enable it, to see if it found anything.
