TheSerpent23's avatar
TheSerpent23
6.6.1 ReadyNas 104 - Not Enough space to rename or move files
After i updated to 6.6.1 i have experienced problems when i try to rename or move a file/folder. It says there is not enough space to rename the file/folder, there are over 130GB free and it says so...
  • StephenB's avatar
    Jan 20, 2017
    That's really quite full for btrfs.  Can you offload some data (perhaps bringing free space up to 10%) and see if the problem still happens?
ProSupport for Business
