TheSerpent23
Jan 20, 2017Aspirant
6.6.1 ReadyNas 104 - Not Enough space to rename or move files
After i updated to 6.6.1 i have experienced problems when i try to rename or move a file/folder. It says there is not enough space to rename the file/folder, there are over 130GB free and it says so...
- Jan 20, 2017
That's really quite full for btrfs. Can you offload some data (perhaps bringing free space up to 10%) and see if the problem still happens?
Jan 20, 2017Guru - Experienced User
It says there is not enough space to rename the file/folder, there are over 130GB free and it says so in the popup notification.
How full is the volume (% free space)? Are you renaming from the PC (using SMB)?
TheSerpent23
It is about 4% free space.
I am using SMB from a Windows 10 computer. I have tried from other Windows 10 machines, and also from the admin console.
I have tried disabling the Windows Search Index service on the Windows 10 just to be sure.
- StephenBJan 20, 2017Guru - Experienced User
- TheSerpent23Jan 20, 2017Aspirant
I will try to find a USB HD and remove some data from it.
I will let you know later :-)
- TheSerpent23Jan 21, 2017Aspirant
It worked to free up some more space.
I moved 300GB to get to 11% free, and now it works fine.
Guess something must have changed during the update, since it has been running on 3-6% free space in the last 1½ Years without any problems.
Hope it will be possible again, so i dont loose 300GB of storage :-)
Thanks for all your help.
