alexofindy
May 29, 2012Aspirant
8 TB expansion limit needs to be documented!!!
This is negative feedback. The reader is forewarned. I am an unhappy camper.... I have a Ultra 6 PLus that is about a year old. I now find myself in the same position as mearglen, as described i...
Nov 24, 2012Guru - Experienced User
I'd rather see it fixed than documented. For instance, by having the system do an off-line expansion when the 8 TB limitation gets in the way.
