ahpsi1
Aug 26, 2014Tutor
8 Terabyte Hard Drive
http://www.seagate.com/about/newsroom/press-releases/Seagate-ships-worlds-first-8TB-hard-drives-pr-master/ On a clear disk you can see forever.
Sep 10, 2014Guru - Experienced User
They're using SMR in the 10 TB model - which increases storage capacity by about 25% over the perpendicular recording being used today (e.g, the 8 TB version).
Though several reports say that SMR drives are particularly sensitive to vibration, which would be an issue in the NAS.
