Sandshark
Nov 14, 2019Sensei
A few bugs I have found while puttering around with a test system
The following are some bugs I have discovered in my various experiments. Since there is no specified place to post them, here they are. Each one has been observed more than once and during a proces...
kohdee
Nov 21, 2019NETGEAR Expert
Warning regarding mixed drive types in single-drive JBOD volume.
Yes, this comes up because md0 is across all disks, including single volume JBODs. it's a warning because we do actually create a RAID that spans all disks. Your OS could be impacted.
Inability to create share on newly created volume without reboot.
This could be setup specific. I haven't been able to reproduce this.
Reference to backup button job when button not pressed -- test unit does not even have a backup button.
Minor inconvenience.
Home folders not properly moved when primary volume is deleted.
Not a bug. We put the apps and home folders on what we call 'default volume'. We have been looking into migration options for apps and home folders.
- SandsharkNov 21, 2019Sensei
kohdee wrote:Home folders not properly moved when primary volume is deleted.
It's not a bug if one deletes the "default volume" and a new (empty) home folders share is not created? It would be great if you did implement a way to actually migrate the content of them and apps, but that's not what I'm pointing to here.
