alexofindy
Aug 28, 2014Aspirant
a few items from my wish list....
1) Better support and documentation on volume encryption - how to create an encrypted volume (this is nowhere accurately and completely documented), info on what the expected performance degradation ...
xeltros
Aug 28, 2014Apprentice
1- There is a huge performance hit on lower end models. I just didn't look into it so I can't help you to set it up right now. If I find some time and motivation to look at it I'll come back at you with a step by step guide.
see last message : viewtopic.php?f=21&t=75345&
2- There is indeed an 8Tb expansion limit for old models. I believe this is an addressing problem and I am not sure this could be addressed by doing an offline expansion. I am not specialist of the question though.
3- There is a way to change linux permissions with OS6, the file access tab on the settings for a share gives you some possibilities. You could reset the rights, you can set permissions and you can block rights inheritance. Maybe there is an option while backing up to "forget" original permissions on the old NAS. Once Again, I only have an OS6 device, so not expert here.
4- If you mean the possibility to set rights once for all protocols, I totally agree.
