alexofindy
Aug 28, 2014Aspirant
a few items from my wish list....
1) Better support and documentation on volume encryption - how to create an encrypted volume (this is nowhere accurately and completely documented), info on what the expected performance degradation ...
xeltros
Aug 29, 2014Apprentice
The post quoted above just said things wouldn't work with 64bit yet, this was two years ago and concerned an utility (resize2fs) that is not, AFAIK, linked in any way to the kernel but linked only to EXT4 that is built in the kernel. So unless EXT4 doesn't support it at all (which is not the case since factory reset is solving the problem) I don't see why there should be a need for a new kernel. So given what I know, I don't think there is a problem as long as you get the updated version of the utility, but you seem to know more than I do, so I'll trust you on this.
For the backup, a minimum of 3 backups is recommended and should allow you to do the factory reset safely.
