ZTMBUS
Oct 07, 2011Aspirant
access problem - lost network connection
hi the almighty forum, I hope you can help me out! I have readynas DUO, 3 years od. Just a while ago after I came back from a short vacation, i could not get access to this network drive, neither co...
Oct 08, 2011Guru - Experienced User
Not the best news.
ZTMBUS wrote: it gets a little more weird. when I turned it off and restarted it this time, there are no lights on the front panel, only the fan noise (fan is running)! i had to unplug the power cable. seems like the machine can not restart :((((((
ztmbus
Try powering down, removing the drives, and powering up. If Raidar can't find the NAS (with "no disks detected"), then it is a the chassis hardware. Most likely that is the case, but the disk removal rules out any possibility of something strange in the boot partition.
