ZTMBUS
Oct 07, 2011Aspirant
access problem - lost network connection
hi the almighty forum, I hope you can help me out! I have readynas DUO, 3 years od. Just a while ago after I came back from a short vacation, i could not get access to this network drive, neither co...
ZTMBUS
Oct 08, 2011Aspirant
indeed.
there is no lights at all (there was one quick blink of all indicators after power button push, then die away, including the power LED), only fan funning. as you suggested, i removed the two disks, tried, got the same result.
i dont know if there is a magic reset button or anything? it is hard to believe this would be a hardware issue.
