ZTMBUS
Oct 07, 2011Aspirant
access problem - lost network connection
hi the almighty forum, I hope you can help me out! I have readynas DUO, 3 years od. Just a while ago after I came back from a short vacation, i could not get access to this network drive, neither co...
Oct 08, 2011Guru - Experienced User
I think it is almost certainly a hardware problem. You should probably open a support case, and sort out your repair and data recovery options.
There is a paper-clip reset button on the back of the ReadyNAS, but you need to be very careful if you use it with the disks inserted - you don't want to do a full reinstall, as that would erase your drives.
