Reeds_dev's avatar
Reeds_dev
Initiate
Apr 01, 2017
Access to ReadyNAS with Android mobile phone
I took over my ReadyNAS from a collegue. Now the ReadyNAS is runnin g but I can't get access with my mobile Android phone. All the answers I get from the interenet tell me that I have to usethe  Read...
  • JennC's avatar
    JennC
    Apr 07, 2017
    Hello Reeds_dev,
    If you are not the first owner, you cannot register the unit itself to the support team to take advantage of the support and warranty but that does not mean you can no longer use the product and access it through ReadyNAS Remote.
    Your NAS must have been configured already wit ReadyNAS Remote before.
    Let me tell you first, ReadyNAS Remote is not ReadyCloud but both are use for accessing the shares of the NAS remotely. you might come across with ReadyCloud, do not get confused. ReadyCloud is for ReadyNAS OS6 units such as RN102, RN104, RN314, etc. ReadyNAS Remote is ReadyNAS OS4 and ReadyNAS OS5 units like the one you are currently using.
    To access your ReadyNAS system from your remote device (computer, smartphone, or tablet), you must first set up ReadyNAS Remote on your ReadyNAS system. Please see page 13 of the ReadyNAS Remote user manual.
ProSupport for Business
