Fabc68
Oct 14, 2025Aspirant
Access to the admin webpage
HI Everyone I have a ReadyNas since 2012. I had in the past some difficulty to access to the admin page because of error message (website not sure, invalid certificate, expired certificate and so...
Fabc68
Oct 21, 2025Aspirant
Here some screenshot
On pic 1, you can see that I am able to mapped the drive and it is found on the local network (add some file)
On pic 2, Raidar says "there is not Netgear devices on your local network""
ON pic 3, Firefox says "can not reach the address"
thanks for your help and time, Fab
Oct 21, 2025Guru - Experienced User
Fabc68 wrote:On pic 1, you can see that I am able to mapped the drive and it is found on the local network (add some file)
Try powering down the NAS and then remove the two drives. Label them by slot as you remove them.
Power it back up and see if RAIDar finds it then.
(If you reinsert the drives after this test, then be careful to do that with the NAS powered down).
