Fabc68
Oct 14, 2025Aspirant
Access to the admin webpage
HI Everyone I have a ReadyNas since 2012. I had in the past some difficulty to access to the admin page because of error message (website not sure, invalid certificate, expired certificate and so...
Fabc68
Oct 27, 2025Aspirant
Did not change anything with or without the drives. It is unexplainable, you can map the NAS as drive, add files but RAIDar can not see it.....
Oct 27, 2025Guru - Experienced User
Fabc68 wrote:Did not change anything with or without the drives. It is unexplainable, you can map the NAS as drive, add files but RAIDar can not see it.....
Likely internet security or antivirus software on the PC is preventing RAIDar from finding the NAS. Some of these packages block the broadcast packets which RAIDar uses to find the NAS.
Are you still unable to access Frontview using Firefox ( with the change to security.tls.version.min )?
