Fabc68
Oct 14, 2025Aspirant
Access to the admin webpage
HI Everyone I have a ReadyNas since 2012. I had in the past some difficulty to access to the admin page because of error message (website not sure, invalid certificate, expired certificate and so...
Fabc68
Oct 28, 2025Aspirant
yes unable to access Frontview with security.tls.version.min at 1
I tried with my antivirus (intego) off, still no access
- StephenBOct 28, 2025Guru - Experienced User
Is this using https://192.168.1.13/admin
Did RAIDar give you any information with intego turned off? (Also turn off the windows firewall if it is turned on).
- Fabc68Nov 03, 2025Aspirant
I abandoned....
I turned off everything I can imagine (anti-virus, firewall, internet filtering...) nothing changed
And then I remembered that I have a very old macbook in a drawer, took it and with this one, I can access Frontview.
So I will use this low cheap solution, until I will buy a new NAS and copy everything on.
So adivce on which NAS, I should buy
thank you
- StephenBNov 03, 2025Guru - Experienced User
Fabc68 wrote:
So advice on which NAS, I should buy
I've only owned ReadyNAS, so no personal experience.
- Are you only interested in storage? Or do you want to run applications (plex, etc) on the NAS?
- What performance would you want in the next one?
- Many support NVME drives as well as SATA (and several are only NVME).
- Are you ok with gigabit ethernet? Or would you want multigig and USB-C as well?
NasCompares has useful information - both on his youtube channel and his website.
