Sly_Raskal
Apr 13, 2021Guide
Account rename
Are there any downsides or potential issues with renaming a user account? I would like to avoid having to create a new account with the preferred username and then transfer files from the old to ...
Apr 14, 2021Guru - Experienced User
I don't know of any downside to just changing the user name.
Though you can't change admin of course.
Sandshark
Apr 14, 2021Sensei
I just ran some tests, and did not find any issues. File and folder permissions follow the UID, of course, so no issues there. And the user folder is properly renamed and made accessable via SMB and NFS. I don't have a way to test other protocols.
It does require that you put in a password for the "new" user, so it'll be changed unless you know the old one and just put it in again.
- Apr 16, 2020Retired_Member
