AndrewNZ
Oct 07, 2018Aspirant
Activity light activity
I have just set up my RN212, installed 2x4TB drives, allowed for disk setup (4 hours), and set up a disk synch with one drive on my pc. That's all synchronised and done.
However every 5 seco...
Oct 08, 2018Guru - Experienced User
Note you picked the wrong ReadyNAS model in your model tag. What you picked is the old Duo v1 (2008 product).
What firmware are you running, and what apps are installed? Did you try tempoarily turning ReadyCloud off in the NAS web UI?
FWIW, I am not seeing any blinking of the activity light on my RN202. That is running 6.9.4, and is not in ReadyCloud.
AndrewNZ
Oct 13, 2018Aspirant
I turned off the readycloud connectivity and the activity light has stopped.
So we're back to "is this normal"?
I have it turned on because part of my plan is to reduce the amount of personal information I keep on google drive, so I can access it directly. Though mobile connectivity is fairly slow and my phone instantly reports the app as a" power intensive app running in the background". But that's another topic.
