cyse
Feb 05, 2012Aspirant
Added the 4th disks but it is not RAID1
Hello everybody, I just added my fourth 3tb hdd to my Ultra4. It did the restripping for 20h or so. I have 3 other 3tb disk inside. After the restripping it merge the data c: from 5400 gig to 8100...
mdgm-ntgr
Feb 06, 2012NETGEAR Employee Retired
TeknoJnky wrote:
The only way to switch to 'raid-1' is to factory default (you must back up all data, everything will be deleted), switch to 'flex-raid' mode using RAIDAR, then delete any default volume and configure the 4 disks however you wish.
Download RAIDar (http://www.readynas.com/downloads). After initiating the factory default the NAS will run a few tests and then a 10 minute window will open where you can open RAIDar, click setup and choose Flex-RAID.
