cyse
Feb 05, 2012Aspirant
Added the 4th disks but it is not RAID1
Hello everybody, I just added my fourth 3tb hdd to my Ultra4. It did the restripping for 20h or so. I have 3 other 3tb disk inside. After the restripping it merge the data c: from 5400 gig to 8100...
Feb 06, 2012Guru - Experienced User
Yes. You have a 10 minute window to set the raid mode. This is done from your PC (using RAIDar). Keep in mind that your password goes back to factory default.
cyse wrote: When i will do factory reset, does i need to do something particular like choosing a special menu to raid1 ?
Also, if you upload your old config, remember to reinstall your add-ons manually first.
