reblut
Jun 17, 2012Aspirant
Adding a volume failed
I am reaching 80% of storage use on my 2 volumes (2T each) NAS. So I decided to add another disk. I bough the same type (seagate baracuda) but 3T. When I add the disk I receive this message: The ...
mdgm-ntgr
Jun 17, 2012NETGEAR Employee Retired
Is this a NV+ (v1 - silver chassis) or a NV+ v2 (charcoal chassis).
The NV+ (v1) does not support 3TB drives. The NV+ v2 does support 3TB drives.
If you have the NV+ (v1) then the drive would recognised a drive with less than 1TB in capacity hence the issue. I would suggest getting another 2TB drive.
