5h1nj1
Sep 27, 2012Aspirant
Adding a WD20EARX to original Readynas Duo
Hi, I would appreciate some help from more experience Readynas users. After some terrible experience I had with the official Netgear support, I will try here, perhaps with more luck. I run a Ready...
5h1nj1
Ok, that's bad news. It will take two days at least to do that. Probably more with all that syncing afterwards. :(
The disk is on the HCL without any notes at all. If there was at least noted that I need 4.1.7 or newer and the transition includes data wipe, I might have chosen a different approach completely. Now it's too late.
Would you know, how are the files/folders access rights handled during this process? I have several users with different access rights and would like to keep that. Will just copying data back and restoring configuration preserve these rights?
Last question: I'm kind of unclear on whether I can use the latest Radiator upgrade (4.1.10) directly or do I need to do the previous upgrades one by one? In short, does 4.1.10 contain all previous upgrades?
And thanks a lot, mdgm, for a quick response. I really appreciate that.
