jrfinkel
May 18, 2021Aspirant
Admin page keeps refreshing...time off after 6.10.5 hotfix
I just applied the 6.10.4->6.10.5 hotfix. The files are accessible from Windows Explorer, but I cannot do any maintenance via the web page (I tried in various browsers) because the admin page keeps...
jrfinkel
Thank you for your prompt reply. Yes, as I recall, the NAS was setup to use an NNTP server.
Interestingly, https does not work and reverts to http because of an invalid cert. That MAY be part of the problem.
Running SSH from a Windows Powershell session returns ssh: connect to host 192.168.1.71 port 22: Connection refused
This is probably because I never set up SSH access and according to documentation, "SSH access is disabled by default." It seems that SSH access can only be opened via the web page, which, of course, is not an option.
Reinstalling the OS is also not an option. I have hundreds of GB of data and I would have to move them to a spare drive, which I do not have. Then I would have to reinstall PHP, PostgreSql, and Plex.
As I mentioned, all was working well (save for the invalid cert) before the hotfix.
Thanks again,
Joel
May 18, 2021Guru - Experienced User
Then the next step is to see if the time is actually being updated. If you have the log zip file, you can look in connman.log for stuff like this:
May 02 06:20:54 RN102 connmand[1964]: ntp: adjust (slew): +0.000374 sec
Did you set up the NAS to use DHCP? A misconfigured network could result in breaking NTP. For instance, leaving out the DNS server(s) when you configure a static address.
