jrfinkel
May 18, 2021Aspirant
Admin page keeps refreshing...time off after 6.10.5 hotfix
I just applied the 6.10.4->6.10.5 hotfix. The files are accessible from Windows Explorer, but I cannot do any maintenance via the web page (I tried in various browsers) because the admin page keeps...
homer51502001
Jun 19, 2021Aspirant
NETGEAR - what are you doing, way to evaporate any faith in your product.... the NAS was "stable" for many months, after an OS Reinstall, back to the Wizard (which looked fine - first attempt was done without disks in place, then once that looked ok I rebooted with the 4 disks in situ, again it didnt take the recent OS install) so try again NAS appears on the network but again unable to browse the GUI or the drives using Windows explorer as the admin creds wont take...
- homer51502001Jun 19, 2021Aspirant
can we boot using the USB to an older version that is stable??
- StephenBJun 19, 2021Guru - Experienced User
homer51502001 wrote:
after an OS Reinstall ... first attempt was done without disks in place
That is a waste of time, since the OS reinstall just reinstalls the the OS onto the disks. The system boots from the disks.
unable to browse ... the drives using Windows explorer as the admin creds wont take...
That is not the usual symptom. Reports here are that issue affects log in to the web ui and ssh - but not file explorer.
If you successfully did the OS reinstall, try using password as the admin password.
Some have been able to downgrade using USB recovery.
hi, yes I have been using the default, that is how I know the GUI keeps reloading as the credentials are used each time, as for not using the disks, well the NAS did boot and I was able to bring up the wizard without disks installed, the reason I took out the disks was my concern that the NAS did something stupid and wipe the sensative data.... so at this time I am using the RAIRar as there is a prompt about delays / unresponsiveness but considering its been up for 7 hours and only at 10% it might be a while before I can test the issue.
at this time, no change - admin page keeps reloading after 20 secs, and in file explorer, NAS is on the network but I get prompted for admin details, so admin / password doesn't work. - is this because the processes are chewing the resources?? you would hope not, but this is Netgear and I have had a NAS fall over before because of a back plane issue and I needed to find an identical model many years later so I wont be surprised...
next step will be support and trying to revert back to a known working fw build.
- jrfinkelJun 19, 2021Aspirant
It has been 4 weeks since I first reported this bug. It is unconscionable that NETGEAR has failed to address this issue and has left all of us who use this product--which I assume is still begin supported--with no way to manage the NAS.
