DavyV
Feb 01, 2017Aspirant
Admin password lost
Hey there everyone, I'm having a problem here with my admin login. I did a OSreinstal and allready reseted him to the Factory settings though the admin login doesn't work. Well the password does...
bedlam1
Feb 01, 2017Prodigy
Which model ReadyNAS do you have and whch Firmware have you re-installed
Feb 01, 2017Guru - Experienced User
Newer ReadyNAS (firmware 5.x.x and 6.x.x) use admin/password as the default.
Older NAS (firmware 4.1.x and 4.2.x) use admin/netgear1 as the default. A very old ReadyNAS might use admin/infrant1
- DavyVFeb 02, 2017Aspirant
Hey there StephenB,
Thank you so much, I forgot to mention the firmware... indeed it was the default passwoord for the 4.1.x ...
Thanks!
- mdgm-ntgrFeb 02, 2017NETGEAR Employee Retired
That's the default password for RAIDiator 3.x and earlier. I think RAIDiator 4 was released late 2007 if I recall correctly.
- lgdqFeb 16, 2017Aspirant
Hello everybody. Same thing for me, after installation of new harddiscs via RAIDar it's impossible to get connected (I am under Mac OS). I use the mentionned admin/password, as well as the previous ones I had, but nothing works and the support is closed to me as my RN10400 is too old for them.
Anyone can help ? Thank you
- StephenBFeb 17, 2017Guru - Experienced User
With the RN104 the default admin password is password.
What status is RAIDar giving you for the NAS?
- May 30, 2016Retired_Member
