Krib
Mar 15, 2014Aspirant
Advice about replacing Duo v1 drive
I have a Duo v1 on 4.1.13 firmware, with a RAID 1 volume that has been functioning on one disk for some time (it does have USB backup). I'd like to get around to finally replacing the second disk in t...
Mar 15, 2014Guru - Experienced User
ST2000VN000 is the NAS drive.
If you hot-swap the ST2000VN000, you should keep the same volume size. To increase it, you'd then need to hot-swap the second drive.
