john_h1's avatar
john_h1
Tutor
Aug 29, 2016
Advice on replacing ReadNAS Pro 6 with 2x 4 Bay ReadyNAS boxes.
I have a ReadyNAS Pro 6 with 6 x 3TB drives in Raid X which I think gave me 12TB of usable storage.
My ReadyNAS recently suffered some sort of corruption that made the volume inaccessible. This has made me realise that I need to have a more robust plan to backup data.  The one box is great to protect against individual drive failures but not loosing the whole raid away via software corruption.
Luckly, I did have all my really important data backed up, so the stuff I have lost is inconvenient but not the end of the world.
so what I am thinking is buying two 4 bay ReadNAS boxes. One will be the N in daily use and the other will be backup of the main box.  I seem to recall built in functionality that enables ReadyNAS boxes to backup to another ReadyNAS?
with that in mind I'm looking at getting a ReadyNAS 314 as the main box and a ReadyNAS 204 as the backup. I will put 4x 3TB drives in each for starters but plan to upgrade to larger dives over time.
what will be the usable space on each box with the 3TB drives?
When I add a larger drive, will the extra space be available or will I have to wait until all drives are larger? I seem to recall something about the raid being based on the smallest drive?
any other thoughts on what I'm planning?
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      The limitation where we used the capacity of the smallest disk was for X-RAID on our legacy Sparc boxes. We discontinued the last of those several years ago now.
      On newer boxes than that we use X-RAID2. With the default single-redundancy (uses RAID-5 with three or more disks) you would get the capacity of your drives summed minus the capacity of the largest disk minus some overheads.
      With X-RAID2 dual-redundancy (uses RAID-6 and thus requires a minimum of four disks) you would be limited to the capacity of the 4th largest disk (as a RAID-6 layer requires a minimum of four disks)
      • john_h1's avatar
        john_h1
        Tutor
        Thanks guys.
        If I have two boxes then I think RAID 5 with single redundancy will provide enough protection and provide for my incremental upgrade to bigger disks.
ProSupport for Business
