musistorr
Apr 25, 2015Aspirant
Advice re which hdd for Duo v1
Hi folks! I wondered if it might be best to ask here first before I buy a spare disc... I'm using the Duo v1 and both discs are the same age/size: Samsung EcoGreen 1.5tb Can I use any other 3.5inch ...
musistorr
Thanks Stephen for a very informative and helpful reply.
[emoji4][emoji106]I just know that I need to cover my back as both my existing drives are quite well used - although health is good on them according to the Netgear diagnostic tab.
It's my first foray into NAS/streaming audio hence the question. I have backed up as well tho to a portable hd: I have learned that a nas in raid array isn't about back up as such but continuity which I do like. I hate to be listening and it go pop so I'm stuck till PC World opens!![emoji38]
