tkevans
Nov 09, 2021Apprentice
Anti-Virus Not Updating on ReadyNAS 204/Firmware 6.10.5 Hotfix 1
I see others noting anti-virus has stopped updating, with recommendations to update firmware. My ReadyNAS 204 with firmware 6.10.5 Hotfix 1 insists no updates are available. Is this model now not s...
Nov 09, 2021Guru - Experienced User
As posted several times now: Netgear always releases firmware for manual installation first. After a lag of 1-2 weeks it is put on the update servers, and will show up in "check for updates".
You can either wait for that to happen, or manually install it from https://kb.netgear.com/000064345/ReadyNAS-OS-6-Software-Version-6-10-6
tkevans
Nov 12, 2021Apprentice
Thanks for the reply, and the link to the manual download. However, when I try to install it, I get "unrecognized server error" message. As noted, I'm at Firmware "6.10.5, Hotfix 1" and setting "update method" on my system is set to "beta." Nothing in logs. Are there additional error logs I can look at by manually logging into the ReadyNAS via command line?
- StephenBNov 12, 2021Guru - Experienced User
What browser are you using?
- tkevansNov 12, 2021Apprentice
Google Chrome, version 95.0.4638.69 (Official Build) (64-bit). Fedora Linux 34.
