tkevans
Nov 09, 2021Apprentice
Anti-Virus Not Updating on ReadyNAS 204/Firmware 6.10.5 Hotfix 1
I see others noting anti-virus has stopped updating, with recommendations to update firmware. My ReadyNAS 204 with firmware 6.10.5 Hotfix 1 insists no updates are available. Is this model now not s...
tkevans
Nov 12, 2021Apprentice
Thanks for the reply, and the link to the manual download. However, when I try to install it, I get "unrecognized server error" message. As noted, I'm at Firmware "6.10.5, Hotfix 1" and setting "update method" on my system is set to "beta." Nothing in logs. Are there additional error logs I can look at by manually logging into the ReadyNAS via command line?
Nov 12, 2021Guru - Experienced User
What browser are you using?
- tkevansNov 12, 2021Apprentice
Google Chrome, version 95.0.4638.69 (Official Build) (64-bit). Fedora Linux 34.
- StephenBNov 12, 2021Guru - Experienced User
Ok. FWIW, I haven't seen this issue with Chrome (though my systems are Windows 10).
Can you click cancel when you see this (and proceed)?
StephenB wrote:
tkevans wrote:Google Chrome, version 95.0.4638.69 (Official Build) (64-bit). Fedora Linux 34.
Cancel exits the whole process. Just tried the install with FireFox 94.0; same error message; cancel simply exits back to the setting screen.
Is there a command-line install from the zip file? That is, login in via a terminal to the ReadyNAS and work at shell prompt?
