Astra03
Oct 05, 2025Apprentice
AntiVirus No Longer Updating
Since 30th September, I have been getting an email from my RN214 advising me that the "Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I ...
Astra03
Thanks for the reply - you have confirmed what I had already suspected.
"The ClamAV software on the NAS was built from source by Netgear, so only they can fix it."
Just a thought, but would it be possible for users the build an up-to-date version of ClamAV from the source code on the ClamAV website? I have no idea how to go about this, though as a desktop user of Linux I know that some people like to build their own apps from source.
Or is antivirus too embedded in the operating system for this to work?
I'm guessing that the only thing I can do is to disable AntiVirus in the ReadyNAS GUI, to stop the database update failure emails?
I don't think that there is any point in running antivirus with an out of date database - is there?
