Astra03
Oct 05, 2025Apprentice
AntiVirus No Longer Updating
Since 30th September, I have been getting an email from my RN214 advising me that the "Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I ...
HansRL
Oct 26, 2025Apprentice
stopping CLAMAV of telling me the every time 'Antivirus scanner definition file update failed due to download failure', I entered the following command via a SSH-connection:
systemctl stop --now clamav-freshclam.timer
ozray
Jan 02, 2026Aspirant
Thanks for that, but I get the following response;
Failed to stop clamav-freshclam.timer: The name org.freedesktop.PolicyKit1 was not provided by any .service files
See system logs and 'systemctl status clamav-freshclam.timer' for details.
What should I do nest?
- StephenBJan 02, 2026Guru - Experienced User
ozray wrote:
What should I do next?
Simplest thing is to turn off the service.
Were you logging in as root when you connected with ssh?
- ozrayJan 02, 2026Aspirant
Hi StephenB
I logged in with admin and password
Instead log in as root (using the admin password).
- DaveRukJan 02, 2026Star
Unless I've missed some other aspect of this one (and please correct if I have)...
...I've just altered the Alert settings on my NAS, and will see if the (now rather pointless) daily message "Antivirus scanner definition file update failed due to download failure" continues to appear, it shouldn't though.
So I've left the service itself running, as I still feel that any AV signature and process is better than nothing, even if it is outdated. End of the day I don't have any external traffic going direct to the NAS, and anything I download etc is scanned on local clients, which are kept up to date, before going anywhere near my NAS systems.
No, it's not a fix/solution in the fullest sense, but hopefully deals with a tiresome daily nag message!- StephenBJan 03, 2026Guru - Experienced User
Disabling AV alerts will prevent the email notifications, but won't stop the logging.
You could also try HansRL's suggestion - entering systemctl stop --now clamav-freshclam.timer from SSH (logged in as root). That will need to be re-entered every time you reboot the NAS (unless you make a mod to the startup scripts).
