Astra03
Oct 05, 2025Apprentice
AntiVirus No Longer Updating
Since 30th September, I have been getting an email from my RN214 advising me that the "Antivirus scanner definition file update failed due to download failure. Check your Internet connection." I ...
ozray
Jan 02, 2026Aspirant
Thanks for that, but I get the following response;
Failed to stop clamav-freshclam.timer: The name org.freedesktop.PolicyKit1 was not provided by any .service files
See system logs and 'systemctl status clamav-freshclam.timer' for details.
What should I do nest?
Jan 02, 2026Guru - Experienced User
ozray wrote:What should I do next?
Simplest thing is to turn off the service.
Were you logging in as root when you connected with ssh?
