mdmahboob
Nov 09, 2021Follower
Antivirus Not updating ReadyNAS 424
Hi,
Please find the details Antivirus not getting updated.
Model ReadyNAS 424
Firmware: 6.10.5 Hotfix 1
Welcome to ReadyNASOS 6.10.5
Last login: Fri Nov 5 16:11:27 2021 from desktop-5r7g5bp
root@TDNAS:~# freshclam
ClamAV update process started at Tue Nov 9 15:28:07 2021
WARNING: Your ClamAV installation is OUTDATED!
WARNING: Local version: 0.100.2 Recommended version: 0.103.4
DON'T PANIC! Read https://www.clamav.net/documents/upgrading-clamav
main.cld is up to date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr )
WARNING: getfile: Unknown response from database.clamav.net (IP: 104.16.218.84): HTTP/1.1 403
WARNING: getpatch: Can't download daily-26338.cdiff from database.clamav.net
WARNING: getfile: Unknown response from database.clamav.net (IP: 104.16.219.84): HTTP/1.1 403
Trying host database.clamav.net (2606:4700::6810:da54)...
nonblock_connect: connect(): fd=4 errno=101: Network is unreachable
Can't connect to port 80 of host database.clamav.net (IP: 2606:4700::6810:da54)
Trying host database.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host database.clamav.net (IP: 2606:4700::6810:db54)
WARNING: Incremental update failed, trying to download daily.cvd
WARNING: Can't download daily.cvd from database.clamav.net
Trying again in 5 secs...
ClamAV update process started at Tue Nov 9 15:28:14 2021
main.cld is up to date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
ClamAV update process started at Tue Nov 9 15:28:20 2021
ClamAV update process started at Tue Nov 9 15:28:25 2021
ClamAV update process started at Tue Nov 9 15:28:31 2021
ERROR: getpatch: Can't download daily-26338.cdiff from database.clamav.net
ERROR: Can't download daily.cvd from database.clamav.net
Giving up on database.clamav.net...
WARNING: getpatch: Can't download daily-26338.cdiff from db.cn.clamav.net
ERROR: getpatch: Can't download daily-26338.cdiff from db.cn.clamav.net
Trying host db.cn.clamav.net (2606:4700::6810:da54)...
Can't connect to port 80 of host db.cn.clamav.net (IP: 2606:4700::6810:da54)
Trying host db.cn.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host db.cn.clamav.net (IP: 2606:4700::6810:db54)
ERROR: Can't download daily.cvd from db.cn.clamav.net
Giving up on db.cn.clamav.net...
ClamAV update process started at Tue Nov 9 15:28:32 2021
WARNING: getpatch: Can't download daily-26338.cdiff from db.tw.clamav.net
ERROR: getpatch: Can't download daily-26338.cdiff from db.tw.clamav.net
Trying host db.tw.clamav.net (2606:4700::6810:da54)...
Can't connect to port 80 of host db.tw.clamav.net (IP: 2606:4700::6810:da54)
Trying host db.tw.clamav.net (2606:4700::6810:db54)...
Can't connect to port 80 of host db.tw.clamav.net (IP: 2606:4700::6810:db54)
ERROR: Can't download daily.cvd from db.tw.clamav.net
Giving up on db.tw.clamav.net...
Update failed. Your network may be down or none of the mirrors listed in /etc/clamav/freshclam.conf is working. Check https://www.clamav.net/documents/official-mirror-faq for possible reasons.
Thanks
Mahboob.
update your firmware to 6.10.6: https://kb.netgear.com/000064345/ReadyNAS-OS-6-Software-Version-6-10-6
1 Reply
