rpdmallett
Feb 18, 2010Aspirant
APC Back-UPS CS 350 compatible
Hi, Just bought this and connected it up to the USB port on my ReadyNAS Duo. Works perfectly - ReadyNAS reports time left, % charge, etc. Looks like I'll get about 70 minutes from it, just powe...
ahpsi1
Apr 12, 2010Tutor
Unfortunately APC chooses to use a cable (AP9827) that has a male RJ45 connector on one end and a USB type A male on the other. This may be to allow for other types of signaling however it mostly serves to be a source of revenue should you lose your cable. If you look on the diagram:
You would connect this cable to the 'data' port:
Hope that helps,
Bill
Hope that helps,
Bill
