mhsimkin
Jul 04, 2011Aspirant
APC Back-UPS Pro 1300 (BR1300G) is it compatible?
Hi:
I have a APC Back-UPS Pro 1300 (BR1300G) on a ReadyNas Ultra running 4.2.17. I've noticed that when a power event occurs. The ReadyNas seems to just drain the UPS and never shutdown gracefully.
Is this UPS supported by the current version of the ReadyNAS O/S?
thanks
marc
thanks
marc
1 Reply
- master64AspirantHi Marc...
have you any news about the compatibility problem..
I need to change my old UPS and would like to know if you have solved your doubts..
Thank you very much.
Paul.
