SuperNASman
Jul 09, 2013Aspirant
APC Back-UPS XS 1300 LCD with ReadyNAS Pro 2
I originally tried connecting my APC Back-UPS XS 1300 LCD to my ReadyNAS Pro 2, but the cable I was using was a male USB to female USB with a USB to RJ-45 adapter connected to it. My understanding ...
fastfwd
Jul 11, 2013Virtuoso
StephenB wrote: fastfwd: I think you are confusing RJ45 with ethernet in the first part of your post (edit).
It was more like using the OP's terminology to avoid having to explain too much... But you're right; I probably should have bitten the bullet and explained that the 8P8C connectors that are described in the RJ45 standard are so commonly used to terminate twisted-pair Ethernet cables that an "X-to-RJ45" adapter is undoubtedly not actually that, but really an X-to-Ethernet-over-twisted-pair-terminated-with-an-8P8C-connector adapter. So his USB-to-RJ45 adapter is trying to translate between USB electrical signals carrying CDC protocol and 100BASE-TX electrical signals carrying Ethernet protocol. And with or without the explanation, he doesn't need or want that; he just needs a USB cable that's terminated in the right kind of plug, with the USB wires connected to the right pins of that plug.
