Edmundcramp
Jun 23, 2012Tutor
APC Back-UPS XS-1500 problems
I bought this UPS this afternoon because it's on the hardware compatibility list - but after connecting it to my ReadyNAS Ultra 2 Plus (version 4.2.20), the NAS continuously reboots. I've tried dis...
HERBIEO
Jun 23, 2012Aspirant
Try unplugging power cord and leave it for a couple of minutes, if that dont work maybe try OS reinstall first as that will not destroy data.
OS reinstall. Reinstalls the firmware from the system’s internal flash to its disks. Use the
OS reinstall boot mode when the system crashes and corrupts some configuration files.
OS reinstall boot mode also resets some settings on your system, such as Internet
protocol settings and the administrator password, to defaults.
Edit: sorry my mistake was looking at your profile and see Duo now Corrected.
To perform an OS reinstall:
1. Power off your unit
2. Using a straightened paper clip, press and hold the Reset button.
3. Press the Power button to power on the unit.
4. Continue to press the Reset button until the Power button LED, USB and backup status LED, disk 1 LED, and disk 2 LED are lit
5. Press the Backup button to scroll through the boot mode options.
OS reinstall Disk 2 LED is lit.
Press and release Reset button to confirm your boot menu selection
