oct
Mar 28, 2014Follower
APC BR1000G Back-UPS Pro 1000 compatible with ReadyNas Duo
Sold on amazon.com as "APC BR1000G Back-UPS Pro 1000 Uninterruptible Power Supply", it is compatible with ReadyNas Duo V1. It shows "APC Back-UPS RS1000G, Battery charge: 100%, 50 minutes OK" on th...
bitonda
Jul 06, 2015Aspirant
Hi
looking in the web interface readynas duo V1 (rnd2150v1) seems to be compatible only with network UPS, do you confirm that ReadyNAS duo V1 has also USB support ? I cannot find any reference in the manual. Thanks
