oct
Mar 28, 2014Follower
APC BR1000G Back-UPS Pro 1000 compatible with ReadyNas Duo
Sold on amazon.com as "APC BR1000G Back-UPS Pro 1000 Uninterruptible Power Supply", it is compatible with ReadyNas Duo V1. It shows "APC Back-UPS RS1000G, Battery charge: 100%, 50 minutes OK" on th...
Jul 08, 2015Guru - Experienced User
The duo v1 definitely supports USB connected UPS. I have used it with CyberPower products, but not with APC.
Netgear does not keep UPS compatibility lists, you are limited to what from customers post in this forum.
