galorecomputers
Aug 09, 2012Aspirant
APC Power-Saving Back-UPS Pro 550 (BR550GI)
Hello, I have the following UPS: APC Power-Saving Back-UPS Pro 550 (BR550GI) I have connected it to the following Netgear: Netgear ReadyNAS Pro 2 RNDP2000 2 Bay I have connected the RJ45 to US...
QuackingPlums
Sep 04, 2012Aspirant
Silly question, but the RJ45 end of your cable is plugged into the Data port of the UPS, right? Not one of the network ports?
I have the NV+ rather than the Pro2 but I don’t remember having to do anything special for either my current UPS (550GI, same as you) or its predecessor (500i) in order to get the ReadyNAS to recognise it.
There’s an option to configure the ReadyNAS to monitor a UPS across the network using NUT instead, though I doubt that’s the default option. I can't remember if having that set would prevent the ReadyNAS from recognising a directly-connected UPS. Worth checking just in case...
