turbotim
May 16, 2013Follower
APC UPS Via Network
Hi There, I have a ReadyNas NV+ (RAIDiator Version 4.1.10) connected to my network along with a Windows 2003 Server and a Qnap TS-219P II Nas. I also currently have an APC Back-UPS Pro 900 which fe...
May 16, 2013Guru - Experienced User
Did you try doing this in the reverse? That is, connecting the UPS to the ReadyNAS and monitoring on the Qnap and Windows server?
You'd use the ReadyNAS IP as the address, Name=UPS, User=monuser, Password=pass
ReadyNAS assumes these values, so you could also try configuring the QNAP to use them (leaving the UPS connected to the QNAP).
