Smaky
Mar 27, 2021Guide
Apps not showing up after install
A couple of days ago i Update my old and trusty ReadyNAS 6 Ultra to 6.10.4. Then proceeded to update the apps I have installed in it (Plex and Emby). However, afer updating emby and getting it failin...
mdgm
Mar 29, 2021Virtuoso
Have you checked the apache logs? It could be that it's fallen back to apache safe mode where the apps are not shown in the web admin interface.
Smaky
Mar 29, 2021Guide
Do you mean http.log? There are some errors there indeed... not sure what the implications might be though:
-- Reboot -- Mar 27 16:03:59 ReadyNAS6Ultra systemd[1]: Starting The Apache HTTP Server... Mar 27 16:04:00 ReadyNAS6Ultra systemd[1]: Started The Apache HTTP Server. Mar 27 16:04:05 ReadyNAS6Ultra apachectl[3304]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using ::1. Set the 'ServerName' directive globally to suppress this message Mar 27 16:04:00 ReadyNAS6Ultra apache2[3313]: [ssl:warn] [pid 3313] AH01909: ::1:443:0 server certificate does NOT include an ID which matches the server name Mar 27 16:04:06 ReadyNAS6Ultra apache2[3319]: [cgi:error] [pid 3319] [client 192.168.10.12:52760] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://smakytaky.synology.me:8980/admin/ Mar 27 16:04:06 ReadyNAS6Ultra apache_access[3315]: Admin session started from 192.168.10.12 Mar 27 16:04:08 ReadyNAS6Ultra apache2[3320]: [cgi:error] [pid 3320] [client 192.168.10.12:52876] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://smakytaky.synology.me:8980/admin/ Mar 27 16:04:13 ReadyNAS6Ultra apache2[3321]: [cgi:error] [pid 3321] [client 192.168.10.12:52892] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://smakytaky.synology.me:8980/admin/ Mar 27 16:04:17 ReadyNAS6Ultra apache2[3496]: [cgi:error] [pid 3496] [client 192.168.10.12:52920] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://smakytaky.synology.me:8980/admin/ Mar 27 16:04:17 ReadyNAS6Ultra apache2[3322]: [cgi:error] [pid 3322] [client 192.168.10.12:52922] AH01215: Connect rddclient failed: /frontview/lib/dbbroker.cgi, referer: https://smakytaky.synology.me:8980/admin/ Mar 27 16:04:18 ReadyNAS6Ultra systemd[1]: Reloading The Apache HTTP Server. Mar 27 16:04:19 ReadyNAS6Ultra apachectl[3685]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 16:04:19 ReadyNAS6Ultra systemd[1]: Reloaded The Apache HTTP Server. Mar 27 16:04:19 ReadyNAS6Ultra apache2[3313]: [ssl:warn] [pid 3313] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 16:04:19 ReadyNAS6Ultra apache2[3313]: [mpm_prefork:warn] [pid 3313] AH00167: long lost child came home! (pid 3314) Mar 27 16:04:19 ReadyNAS6Ultra apache2[3313]: [mpm_prefork:warn] [pid 3313] AH00167: long lost child came home! (pid 3315) Mar 27 16:04:19 ReadyNAS6Ultra apache2[3313]: [mpm_prefork:warn] [pid 3313] AH00167: long lost child came home! (pid 3318) Mar 27 16:04:55 ReadyNAS6Ultra apache_access[3710]: Admin session started from 192.168.10.12 Mar 27 16:04:56 ReadyNAS6Ultra apache_access[3710]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 16:05:37 ReadyNAS6Ultra apache_access[3710]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 17:14:04 ReadyNAS6Ultra apache_access[3710]: Suppressed 1 duplicate messages Mar 27 17:14:04 ReadyNAS6Ultra apache_access[3710]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 17:14:08 ReadyNAS6Ultra apache_access[3710]: 192.168.10.12 "POST /admin-cgi/localapp.cgi HTTP/1.1" 200 Mar 27 17:14:49 ReadyNAS6Ultra systemd[1]: Stopping The Apache HTTP Server... Mar 27 17:14:49 ReadyNAS6Ultra apachectl[6056]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:14:49 ReadyNAS6Ultra systemd[1]: Stopped The Apache HTTP Server. Mar 27 17:14:49 ReadyNAS6Ultra systemd[1]: Starting The Apache HTTP Server... Mar 27 17:14:50 ReadyNAS6Ultra apachectl[6169]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:14:50 ReadyNAS6Ultra apache2[6173]: [ssl:warn] [pid 6173] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:14:50 ReadyNAS6Ultra systemd[1]: Started The Apache HTTP Server. Mar 27 17:14:50 ReadyNAS6Ultra apache2[6176]: [ssl:warn] [pid 6176] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:14:51 ReadyNAS6Ultra apache_access[6178]: Admin session started from 192.168.10.12 Mar 27 17:24:36 ReadyNAS6Ultra systemd[1]: Stopping The Apache HTTP Server... Mar 27 17:24:36 ReadyNAS6Ultra apachectl[6852]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:24:36 ReadyNAS6Ultra systemd[1]: Stopped The Apache HTTP Server. Mar 27 17:24:36 ReadyNAS6Ultra systemd[1]: Starting The Apache HTTP Server... Mar 27 17:24:37 ReadyNAS6Ultra apachectl[6978]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:24:37 ReadyNAS6Ultra apache2[6982]: [ssl:warn] [pid 6982] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:24:37 ReadyNAS6Ultra systemd[1]: Started The Apache HTTP Server. Mar 27 17:24:37 ReadyNAS6Ultra apache2[6985]: [ssl:warn] [pid 6985] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:24:37 ReadyNAS6Ultra apache_access[6988]: Admin session started from 192.168.10.12 Mar 27 17:24:37 ReadyNAS6Ultra systemd[1]: Stopping The Apache HTTP Server... Mar 27 17:24:38 ReadyNAS6Ultra apachectl[7119]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:24:38 ReadyNAS6Ultra systemd[1]: Stopped The Apache HTTP Server. Mar 27 17:24:38 ReadyNAS6Ultra systemd[1]: Starting The Apache HTTP Server... Mar 27 17:24:38 ReadyNAS6Ultra apachectl[7243]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:24:38 ReadyNAS6Ultra apache2[7247]: [ssl:warn] [pid 7247] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:24:38 ReadyNAS6Ultra systemd[1]: Started The Apache HTTP Server. Mar 27 17:24:38 ReadyNAS6Ultra apache2[7250]: [ssl:warn] [pid 7250] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:24:39 ReadyNAS6Ultra apache_access[7252]: Admin session started from 192.168.10.12 Mar 27 17:25:25 ReadyNAS6Ultra apache_access[7252]: 192.168.10.12 "GET /admin/ HTTP/1.1" 401 Mar 27 17:25:27 ReadyNAS6Ultra apache_access[7252]: 192.168.10.12 "POST /dbbroker HTTP/1.1" 401 Mar 27 17:25:32 ReadyNAS6Ultra apache_access[7252]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 17:25:54 ReadyNAS6Ultra apache_access[7252]: Suppressed 2 duplicate messages Mar 27 17:25:54 ReadyNAS6Ultra apache_access[7252]: 192.168.10.12 "GET /admin/ HTTP/1.1" 401 Mar 27 17:26:08 ReadyNAS6Ultra apache_access[7252]: 192.168.10.12 "POST /dbbroker HTTP/1.1" 401 Mar 27 17:26:13 ReadyNAS6Ultra apache_access[7252]: Suppressed 2 duplicate messages Mar 27 17:26:13 ReadyNAS6Ultra apache_access[7252]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 17:26:27 ReadyNAS6Ultra apache_access[7252]: 192.168.10.12 "GET /apps/smbplus HTTP/1.1" 301 Mar 27 17:26:52 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /admin/ HTTP/1.1" 401 Mar 27 17:27:00 ReadyNAS6Ultra apache_access[7252]: Suppressed 1 duplicate messages Mar 27 17:27:00 ReadyNAS6Ultra apache_access[7252]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 17:27:02 ReadyNAS6Ultra apache_access[7251]: Admin session started from 192.168.10.20 Mar 27 17:27:04 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "POST /dbbroker HTTP/1.1" 401 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: Suppressed 2 duplicate messages Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus HTTP/1.1" 301 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/ HTTP/1.1" 200 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/js/jquery-1.10.2.min.js HTTP/1.1" 200 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/css/ntgr-theme/jquery-ui-1.10.3.custom.css HTTP/1.1" 200 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/smbplus.js HTTP/1.1" 200 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/smbplus.css HTTP/1.1" 200 Mar 27 17:27:33 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/js/jquery-ui-1.10.3.custom.min.js HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/ajax-loader.gif HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/smbplus.cgi?op=getLocalizedString&ms=1616884023946 HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/netgear-logo.png HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/refreshIcon.png HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/app-logo.png HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/exitIcon.png HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/infoIcon.png HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/images/bg-top.png HTTP/1.1" 200 Mar 27 17:27:34 ReadyNAS6Ultra apache_access[7251]: 192.168.10.20 "GET /apps/smbplus/smbplus.cgi?op=getSmbplusState&ms=1616884024305 HTTP/1.1" 200 Mar 27 17:28:07 ReadyNAS6Ultra systemd[1]: Stopping The Apache HTTP Server... Mar 27 17:28:08 ReadyNAS6Ultra apachectl[9328]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:28:08 ReadyNAS6Ultra systemd[1]: Stopped The Apache HTTP Server. Mar 27 17:28:08 ReadyNAS6Ultra systemd[1]: Starting The Apache HTTP Server... Mar 27 17:28:08 ReadyNAS6Ultra apachectl[9457]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:28:08 ReadyNAS6Ultra apache2[9461]: [ssl:warn] [pid 9461] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:28:08 ReadyNAS6Ultra systemd[1]: Started The Apache HTTP Server. Mar 27 17:28:08 ReadyNAS6Ultra apache2[9464]: [ssl:warn] [pid 9464] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:28:08 ReadyNAS6Ultra apache_access[9466]: Admin session started from 192.168.10.20 Mar 27 17:28:09 ReadyNAS6Ultra systemd[1]: Stopping The Apache HTTP Server... Mar 27 17:28:10 ReadyNAS6Ultra apachectl[9607]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:28:10 ReadyNAS6Ultra systemd[1]: Stopped The Apache HTTP Server. Mar 27 17:28:10 ReadyNAS6Ultra systemd[1]: Starting The Apache HTTP Server... Mar 27 17:28:10 ReadyNAS6Ultra apachectl[9736]: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 192.168.10.10. Set the 'ServerName' directive globally to suppress this message Mar 27 17:28:10 ReadyNAS6Ultra apache2[9740]: [ssl:warn] [pid 9740] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:28:10 ReadyNAS6Ultra systemd[1]: Started The Apache HTTP Server. Mar 27 17:28:10 ReadyNAS6Ultra apache2[9743]: [ssl:warn] [pid 9743] AH01909: 192.168.10.10:443:0 server certificate does NOT include an ID which matches the server name Mar 27 17:28:10 ReadyNAS6Ultra apache_access[9744]: Admin session started from 192.168.10.20 Mar 27 17:30:56 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus HTTP/1.1" 301 Mar 27 17:30:56 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/ HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/css/ntgr-theme/jquery-ui-1.10.3.custom.css HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/smbplus.js HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/smbplus.css HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/js/jquery-1.10.2.min.js HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/js/jquery-ui-1.10.3.custom.min.js HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/bg-top.png HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/ajax-loader.gif HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/netgear-logo.png HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/app-logo.png HTTP/1.1" 200 Mar 27 17:30:57 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/exitIcon.png HTTP/1.1" 200 Mar 27 17:30:58 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/smbplus.cgi?op=getLocalizedString&ms=1616884227608 HTTP/1.1" 200 Mar 27 17:30:58 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/refreshIcon.png HTTP/1.1" 200 Mar 27 17:30:58 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/images/infoIcon.png HTTP/1.1" 200 Mar 27 17:30:58 ReadyNAS6Ultra apache_access[9744]: 192.168.10.20 "GET /apps/smbplus/smbplus.cgi?op=getSmbplusState&ms=1616884228330 HTTP/1.1" 200 Mar 27 17:31:09 ReadyNAS6Ultra apache_access[9745]: ::1 "OPTIONS * HTTP/1.0" 200 Mar 27 17:31:27 ReadyNAS6Ultra apache_access[9745]: ::1 "OPTIONS * HTTP/1.0" 200
