ConfusedOne1
Jan 18, 2012Aspirant
ARM and Sparc
Good day folks, I'm a bit confused with the netgear nas duo v2....the story is this...I bought a Netgear NAS duo RND 2000 V2 a couple of weeks ago with the intent of using some GB disks that I had ...
Jan 19, 2012Guru - Experienced User
My main point is the need to tell what you are getting at the time of purchase (assuming on-line). As V1 inventory is disappearing, that problem will soon vanish, but right now it is still very easy to buy a V1 when you want a V2 (or vice versa). Looking for the -200 in the part number probably the best method there.
