Campus
Jun 22, 2016Luminary
Avoid Seagate ST8000VN0002 - Horrible noise issue!
Hi, I have installed four of the Seagate ST8000VN0002 in my RN716x and just finished the resync of all disks. Unfortunately I now have an annoying beeping/humming noise when the disks are idling....
Shastada
Nov 28, 2016Aspirant
I ordered some of these drives from Newegg and some came with SC61 already loaded but one came with SC60. I would appreciate if you could send me the SC61 upgrade. I can't seem to find it anywhere.
Campus
Nov 28, 2016Luminary
Could you notice a difference between those version? Are the 61 quiet?
- nsneNov 28, 2016Virtuoso
In my limited experience, there is a huge difference between the versions. I had another SC60 arrive from Newegg today and it's making the horrible whine. My upgraded SC61 is cool (110°F) and quiet.
- ShastadaNov 28, 2016Aspirant
I have all mine running in one system, so it's hard to say if the one oddball is making all the noise, but it does sound lounder than I'd like. Hopefully having them all at SC61 will help.
