freddyfruitbat
Mar 18, 2013Guide
Back-UPS ES550UK: setup with ReadyNAS Duo v2. (Powerchute?)
I've just invested in the above UPS to go with my ReadyNAS Duo, having just learned to my cost that to use a one without a UPS in place is a Bad Idea :x however, am struggling a bit to get it set up ...
freddyfruitbat
Mar 19, 2013Guide
StephenB wrote: One pair is intended to protect the NAS ethernet line from a power surge
Ah, I see, thanks: so evidently my connections are correct, but I wouldn't expect to be able to 'see' the UPS via this cable then. What about the issue of configuring the NAS to shut down gracefully (and/or do I need to get this PowerChute add-on installed?
